tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
SamirD
Feb 10, 2015Prodigy
Thank you fordem. I knew there had to be a way using vlans.
fordem wrote: [QUOTE=tachyon_pulse;492414]Is there a way to hide the wired addresses from the WLAN addresses on the same subnet?
Separate VLANs - one per port - on an 8 port switch you can have 7 and the 8th port is a member of all VLANs that links to the FVS318N
