bhenson1
Jun 13, 2014Aspirant
Consistent RDP disconnects
We've had an issue for a while now where RDP connections are dropping every few minutes.
It's happening both ways, RDP connections into our office or out from our office.
This also appears to happen regardless of whether or not we connect over a VPN. It also affects Citrix GoToMeeting.
I'm wondering if it's a firewall setting? It happens very consistently every 10 or 15 minutes or so, all throughout the day. And again, it's both ways, and not limited to any one machine in the office. RDP between systems on the internal network are fine.
I thought it could be an internet connectivity issue, so I ran an internet connectivity monitor from this site: https://code.google.com/p/internetconnectivitymonitor/ and had it attempt to connect to google every 5 seconds for 30 minutes, it didn't report any disconnects, and I generally don't have issues with disconnecting from websites. So I don't think it's an internet connectivity issue.
I also ran a couple of trace routes:
From my house to my office:
Tracing route to 75-150-44-1-Oregon.hfc.comcastbusiness.net [75.150.44.1]
over a maximum of 30 hops:
1 7 ms 3 ms 3 ms 10.0.0.1
2 * * * Request timed out.
3 10 ms 12 ms 12 ms xe-0-3-2-32767-sur04.beaverton.or.bverton.comcast.net [68.85.148.249]
4 11 ms 11 ms 12 ms te-3-0-0-ten11.beaverton.or.bverton.comcast.net [68.85.149.58]
5 19 ms 16 ms 20 ms c-98-246-138-191.hsd1.or.comcast.net [98.246.138.191]
6 21 ms 16 ms 15 ms 75-150-44-1-Oregon.hfc.comcastbusiness.net [75.150.44.1]
From my office to my house:
Tracing route to c-67-189-18-29.hsd1.or.comcast.net [67.189.18.29]
1 <1 ms <1 ms <1 ms 10.0.0.1
2 <1 ms <1 ms <1 ms 10.1.10.1
3 5 ms 5 ms 3 ms 73.90.88.1
4 7 ms 7 ms 40 ms xe-1-1-2-32767-sur04.beaverton.or.bverton.comcast.net [68.85.149.57]
5 7 ms 8 ms 9 ms te-3-0-0-ten07.beaverton.or.bverton.comcast.net [68.85.148.250]
6 17 ms 15 ms 16 ms c-67-189-18-29.hsd1.or.comcast.net [67.189.18.29]
- jmizoguchiVirtuosoYou have SMC modem/gateway?
Static IP account with comcast? - bhenson1AspirantWe have a Netgear CG3000DCR Advanced Cable Modem Gateway supplied by Comcast.
Our network has a static IP of 75.150.44.1. - jmizoguchiVirtuosoIf you are only using CG3000DCR then you are in wrong section
- bhenson1Aspirant
jmizoguchi wrote: If you are only using CG3000DCR then you are in wrong section
The CG3000DCR is just our gateway.
We are also using a NetGear FVS 318 ProSafe VPN Firewall. - jmizoguchiVirtuosoI don't think CG3000DCR will pass public IP on your FVS or does public IP shows WAN of the router (FVS)
- bhenson1AspirantYour right it doesn't appear to be passing that IP to the FVS.
- jmizoguchiVirtuosoCGxx needs to be in bridge mode replace with basic cable modem
- aditMentorI do believe there is an issue with session disconnects. We are seeing the same thing with the ProSafe UTM routers as well. We have the same issue with pcAnywhere disconnects also. Submit a trouble ticket w/ Netgear.
