FrankAKay
May 25, 2012Aspirant
DGFV338 ADSL Board died - can I get a replacement?
We have several DGFV338s, and one has a dead ADSL board, probably Part No TU720F16. CAn I get a replacement for use in the UK? Or since the DGFV338 is no longer current, what should I use as a repla...
jmizoguchi
May 25, 2012Virtuoso
forum is not support
contact support at my.netgear.com
all prosafe has lifetime warranty so likely they will send you new device
