LookLeft
May 05, 2017Aspirant
DGFV338 Whistle
Hi. My DGFV338 has started whistling. No particular tune but it is high pitched and loud enough to be heard. Any solutions as to what to do? Or do I wave it goodbye? Thanks.
LookLeft
May 11, 2017Aspirant
Thanks.
a. Yes, working fine.
b. Yes, still whistling.
c. LED's working as expected.
d. Not yet.
I am pretty sure it is like a transformer whistle, something vibrating.
DaneA
May 14, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try to reset the DGFV338 back to its factory default settings then reconfigure it from scratch? If yes and still same problem, then its a hardware fault on the device. You will need to replace it.
DaneA
NETGEAR Community Team
