DAZ3210's avatar
DAZ3210
DGFV338 and BT Infinity
Is it possible to use my existing firewall router with the BT Infinity Service?
BT are telling me via their website that I must you a HomeHub 3, but surely if I use the external modem socket on teh DGFV I should be able to get a VDSL modem.
I don't want to lose the functionality that the DGFV Unit gives me.
  • Thanks, you can't give a link can you please? Nothing showed up on search.
  • that is for you read though thread... time for your homework
    too many thread to go through.... :)
  • That is my point. I have read all the threads that search gives, and not found the answer to my question.
  • All I can get from BT is that only their hub will work, and their engineer will fit it and set it up
  • Can't speak for BT. BT has been requiring VLAN over WAN on some of their connections. None of the Netgear routers with integrated DSL modems currently support it. It is planned for the UTM9s in a future firmware upgrade. The DGFV338 will not get it. If your new connection requires it (VLAN over WAN) you are out of luck with the DGFV338.
  • Can't speak for BT. BT has been requiring VLAN over WAN on some of their connections. None of the Netgear routers with integrated DSL modems currently support it. It is planned for the UTM9s in a future firmware upgrade. The DGFV338 will not get it. If your new connection requires it (VLAN over WAN) you are out of luck with the DGFV338. There have been recent discussions on the ProSecure forum about this.
