ccmanhattan's avatar
Feb 04, 2024
Orbi 970 and Carrier Infinity Touch Thermostat Model SYSTXCCITC01-A do not talk
Up graded router to new obri 970 and now Carrier Infinity Touch thermostat will not get on line. Have tried loT and main networks. Still no luck.
  • Read comments about a different thermostat and router and they used a $20 TP-link Access Point from amazon. TL-WA801N.Got it today and solved the challenge! Thanks all for the help!
  • plemans's avatar
    When you setup the IoT network, what error did you get? Was your phone on the same IoT network when you went through setup?
      • ccmanhattan's avatar
        ccmanhattan
        Star
        yes on the same network. message was : Unable to connect. Please check your password and network connectivity.
  • CrimpOn's avatar
    CrimpOn
    Is the new 970 system configured with exactly the same WiFi credentials as the previous system? (SSID/password).
    My experience for 20 years has been that WiFi devices connect immediately whenever they detect a WiFi system that they recognize.  Would be a real shock if installing the Netgear 970 did not work the same way.
    • First try was with main network with no luck. Set up IoT network and same results.
      • owlyn's avatar
        owlyn
        Luminary
        Make sure Access Control is turned off.
    • CrimpOn's avatar
      CrimpOn
  • FURRYe38's avatar
    What security mode do you have set on the IoT network? WPA2 and AES only? Temporarily set security to NONE. Then see if the device will connect in the open. Re-enable WPA2 and AES after testing.
    What channels are you using on the RBR?
      • FURRYe38's avatar
        IF thats happening, then there is some incompatibility between these branded controllers and this Orbi system.
