peppercorn's avatar
Jan 10, 2021
Carrier Infinity Touch Thermostat won't connect to Orbi RBK852 (AX6000) WiFi
I just replaced my Orbi RBK50 system with a new WiFi 6 Orbi RBK852 (AX6000) mesh system at my home.  I kept the same WiFi network SSID and password from the RBK50 and all of my devices successfully attached to my new RBK852 system.  All but one device: Carrier Infinity Touch Thermostat (Model SYSTXCCITC01-A).
This is an older smart thermostat that's been installed at my home for just over four years.  I had no problems connecting the thermostat wirelessly to my old Orbi RBK50 system over the past year, but it would not connect to the RBK852.
After much online searching, I found a posting on the Netgear Community: How do I connect my PlayStation 4 to my Orbi WiFi 6 System?
This worked for me!  Summary: change the CTS/RTS Threshold values to 2347 for both the 2.4GHz and 5GHz wireless settings.
  • Yes, NG is defaulting to 64 on there Orbi AX system which for some older devices or some Iot, doesn't work well so setting 2347 is a alternative solution. Glad you got it working. Please mark your thread as solved so others will know.
    Enjoy. :smileywink:
  • FURRYe38's avatar
    Enjoy. :smileywink:
  • Hi,
    I saw the thread about Carrier Infinity Touch not able to connect to AX6000. I have the same problem but with AX4200 (RBS750)
    The solution provided is - "change the CTS/RTS Threshold values to 2347 for both the 2.4GHz and 5GHz wireless settings."
    How to do this? I am a non-tech person.. can someone please send the details (steps) please?
    Thanks
    Arch
    • FURRYe38's avatar
      Use a wired PC and web browser and navigate to 192.168.1.1 or orbilogin.com.
      Under Advanced Tab/Advanced Settings/Wireless Settings to change CTS values.
      Arch666 wrote:
      Hi,
      Thanks
      Arch
      • Arch666's avatar
        Arch666
        Initiate
        I followed th instructions.. thanks FURRYe38 (Guru) :)
        My thermostat is connected to Orbi's network
