mhndsh
Dec 19, 2018Aspirant
DHCP problem SRX5308 – ProSAFE Quad WAN Gigabit SSL VPN Firewall
Hi,
I have less than 100 users with 200 available ips in the dhcp pool..
Latest firmware 4.3.5-3
New clients cannot obtain an ip...
I read the similar topics.. i reset it and reconfigure... But same problem..
Is there any new solution except downgrading?
Thanks.
Thanks.
- JohnC_VNETGEAR Employee Retired
Hi mhndsh,
Have you tried to change the subnet of your LAN from /24 to /16?
- mhndshAspirant
No, but i downgraded the FW and it's ok with old version.. is it a bug in the last version? and what is the last recomended stable version?
thanks
- Nodism1125NETGEAR Expert
Have you tried manually configuring the router setting instead of using the same router config? After upgrading the firmware to version 4.3.5-3.
