golfbird
Aug 08, 2015Tutor
DOI erros
Starting off by excusing my ignorance of this process I have a FVS318v3 router at my office and have been using a prosafe client software from my home for several years on a windows xp Now I a...
- Aug 14, 2015
Hi golfbird,
I am glad that it worked! We'll be reporting the latest version of the firmware and do more tests on win7 and win10.
Thank you for your contribution.
BrianL2
Aug 09, 2015NETGEAR Employee Retired
Hi golfbird,
I have sent you a pm to ask for more info and to speed up the resolution. You may also want to check the articles below for more information.
http://kb.netgear.com/app/answers/detail/a_id/24245/~/client-to-box-vpn
Kind regards,
BrianL
NETGEAR Community
- golfbirdAug 09, 2015Tutor
Thank You
I have read those before, and unfortunately I dont understand all I read
I also have replied to your offer to help, but do not see how I can attach images
so if you would provide me with your email, I can get those screen shots to you.
Just knowing you making an attempt to help this old man out, has made my day.
- SophostryAug 10, 2015Aspirant
There are some differences between the old FVS318v3 and the newer client.
I would use the wizard on the client after using it on the device. The number values would need to be changed. Looking at both articles and comparing them to your device and client on the PC, should get the correct ones in place, though your exchanging them, and so it will be a little odd.
- golfbirdAug 10, 2015Tutor
I’m lost.
I have no idea what you mean.
Sounds great, but it’s a foreign language I don’t understand
That must translate to that there is no hope for me.
Thanks.
