golfbird
Aug 08, 2015Tutor
DOI erros
Starting off by excusing my ignorance of this process I have a FVS318v3 router at my office and have been using a prosafe client software from my home for several years on a windows xp Now I a...
- Aug 14, 2015
Hi golfbird,
I am glad that it worked! We'll be reporting the latest version of the firmware and do more tests on win7 and win10.
Thank you for your contribution.
golfbird
Aug 09, 2015Tutor
Thank You
I have read those before, and unfortunately I dont understand all I read
I also have replied to your offer to help, but do not see how I can attach images
so if you would provide me with your email, I can get those screen shots to you.
Just knowing you making an attempt to help this old man out, has made my day.
Sophostry
Aug 10, 2015Aspirant
There are some differences between the old FVS318v3 and the newer client.
I would use the wizard on the client after using it on the device. The number values would need to be changed. Looking at both articles and comparing them to your device and client on the PC, should get the correct ones in place, though your exchanging them, and so it will be a little odd.
- golfbirdAug 10, 2015Tutor
I’m lost.
I have no idea what you mean.
Sounds great, but it’s a foreign language I don’t understand
That must translate to that there is no hope for me.
Thanks.
- JohnRoAug 10, 2015NETGEAR Employee Retired
Hello golfbird,
I understand that is a bit confusing when using an older router with a new client. First, we have to take note of the public IP of your router, second the LAN network range (ex. 192.168.1.0) and passphrase. Also, we need to take note of the local and remote identifier, see image below:
fig1.
Once you have all the information that we need, we'll go to configuring the client software.
We'll be using the wizard for this one:
fig.2
Enter the necessary information neede (Public IP/WAN IP, passprhase and LAN IP range), click next.
fig.3
Once you have this window, review your settings and click on finish.
fig4
After clicking finish, we should be able to see the main window:
fig.5
Let us click on Ikev1 Gateway>Advanced:
fig.6
Remember we took note of out Local and Remote identifier (see fig.1).
We will enter those information here.
fig.7
Note that they are reversed. Once done, try opening the tunnel.
fig.8
If everything is successful, you should see a "Tunnel open" message on the bottom right hand side of your screen.
I hope this one helps, if you have more questions please feel free to ask.
Thanks,
- golfbirdAug 11, 2015Tutor
I have taken screen shots of the windows in the router
but still having same problems
link above, a pdf file, as I dont know how to show the images like you did
