golfbird
Aug 08, 2015Tutor
DOI erros
Starting off by excusing my ignorance of this process I have a FVS318v3 router at my office and have been using a prosafe client software from my home for several years on a windows xp Now I a...
- Aug 14, 2015
Hi golfbird,
I am glad that it worked! We'll be reporting the latest version of the firmware and do more tests on win7 and win10.
Thank you for your contribution.
golfbird
Aug 11, 2015Tutor
I changed to 192.168.1.0 on the router
And 192.168.1.0 client ipsec page
Subnet on both is 255.255.255.0
That did not connect
I then changed both to 200 200 200 0
And that also did not connect
Log message
Exchange_validate failed: DOI error
I have noticed that you are using 200.200.200.0 as your LAN IP as declared on the VPN auto policy (please take note that this should be you local IP which your devices are using).
However, the one you have declared on the client software is 192.168.1.0. The local IP on the VPN policy and the client software should match.
JohnRo
Aug 11, 2015NETGEAR Employee Retired
Hello golfbird,
I have sent additional questions via PM. Also, if you could provide us your firmware version that would help a lot.
I'll look forward to your response.
Thanks,
- golfbirdAug 12, 2015Tutor
a pdf file with screen shots, hope these are pages,
all from the router
318v4 firmware .028
