kenshipp
Apr 10, 2017Tutor
Firewall FVS336Gv2 VPN Not Working
I've seen some other discussions about VPN problems but nothing that quite describes my problem. I have a FVS336GV2 firewall that I'm trying to set up a site to site IPsec VPN connection with and I c...
DaneA
Apr 11, 2017NETGEAR Employee Retired
Hi kenshipp,
I have searched online about the Zyxel USG40 and found out from its user guide here that its default LAN subnet is 192.168.1.x. The default LAN subnet on the FVS336Gv2 is also 192.168.1.x. Because of this, you will not be able to fully establish a box-to-box VPN connection. You will need to change the LAN subnet of either the Zyxel USG40 or the FVS336Gv2 to a different one. For example, since the FVS336Gv2 has a LAN subnet of 192.168.1.x, you may change the LAN subnet of the Zyxel USG40 to 192.168.9.x or 10.10.10.x.
Let me share the articles below and use it as reference guides:
Configuring a Box to Box VPN on ProSAFE/ProSECURE routers using the VPN Wizard
Virtual Private Networking Using IPsec
Hope this helps.
DaneA
NETGEAR Community Team
- kenshippApr 11, 2017Tutor
Both LANs have been changed to different subnets long ago.
Thanks for the response.
Ken
- DaneAApr 12, 2017NETGEAR Employee Retired
Thanks for the feedback. :)
Kindly check the SA Lifetime values. Let me share these old forum links below that might help as reference:
SA Lifetime Guidelines for VPN Setup
If ever it does not help, kindly post screenshots of the VPN settings (such as IKE & VPN Policies) configured on both FVS336Gv2 and Zyxel USG40.
DaneA
