Kulturidee
Oct 12, 2016Tutor
Firewall FVS336GV2 VPN problem
I have a FVS336Gv2. I can not get VPN with a FRITZ!Box 7490 firmware 6.60. I had tried it with the old firmware Version 3.1.1-08 at the netgear-router and with new firmware version 4.3.3-6. Both times does not work. It displays "IPsec SA Established", but it does not work. Who has a configuration with a FRITZ!Box with a current firmware, which works with VPN on a FVS336Gv2? Can you tell me, which settings you have at VPN Policy? Thank you in advance.
- JohnRoNETGEAR Employee Retired
Hello Kulturidee,
Welcome to the community!
I have not used FRITZBOX so I cannot give you an advice for that. I can help you with checking the configuration on the FVS. If you can post the VPN and IKE policy on both routers we can definitely take a look.
Looking forward to your response.
Thanks,
Hi Kulturidee,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
