kellysmith120
Aug 13, 2019Aspirant
Firewall segmentation
I have a small municipal network of about 20 pc's with a Server 2016 with AD, and an ip network of 192.168.1.x We have a 24 port unmanaged network switch as the main switch. One port runs to anothe...
kellysmith120
Aug 14, 2019Aspirant
I'm aware that an unmanaged switch as we have won't do it. I can't have the firewall on the server (although there is one there), it must be between the main switch and the switch for the police department.
Is there a firewall appliance that will sit between these two switches to satisfy the requirement for the software? Or will I have to use a router in order to have a firewall there?
jec956613
Sep 22, 2019Tutor
This is probably late, but you'll need them both to be on different subnets, with a routing device between the two and can then control traffic in one of two ways:
1) ACLs, dictating which addresses and ports are allowed or not.
2) Stateful firewall, which tracks every connection and is much more hardened.
The first can be done on any standard router (including a switch with L3 routing), the second needs a dedicated firewall device or a router with built-in firewall feature (or theoretically a firewall blade on a bladed switch).
So you'll either need to replace your first unamanged switch with an L3 switch, or install a router placed into classical routing mode between the two existing unmanaged switches. And, to be honest, the router is usually cheaper. :)
