okokok
Nov 26, 2016Aspirant
Firmware file invalid or corrupted
I am trying to upgrade my router's firmware. I receive firmware file is invalid or corrupted when I hit the upgrade button. I see there is a convoluted telnet via Mac and TFTP method that someone use...
DougBird
Dec 09, 2016Aspirant
I'm seeing the same problem. Firmware version is FVS318Gv2_v4.3.4-2. Downloaded (twice) this afternoon using Firefox version 48.0.2. Attempted to install both times using a Mac direcly connected to the firewall and using same Firefox, and got the "Firmware file invalid or corrupted" message both times. Ideas, especially solutions, appreciated.
picsinc
Dec 21, 2016Aspirant
I am experiencing the same issue. My FVS318Gv2 is running firmware 4.3.3-6. I tried to upgrade to any newer versions (4.3.3.8, 4.3.4.1 or 4.3.4.2) and all failed with firmware file invalid or corrupte. I also tried multiple downloads of the firmware and none succeeded in upgrading my router. Modem had been reset to factory default settings and the admin password is the only configuration change I made prior to my attempt in upgrading the firmware. Please help !!
- DaneADec 21, 2016NETGEAR Employee Retired
Hi picsinc,
Welcome to the community! :)
Kindly try to upgrade the firmware of the FVS318Gv2 via TFTP. Kindly access the article below as your guide:
How to upload firmware to a NETGEAR router using TFTP
DaneA
NETGEAR Community Team
- DaneADec 25, 2016NETGEAR Employee Retired
Hi picsinc,
I just want to follow-up on this. Were you able to try to upgrade the firmware of the FVS318Gv2 via TFTP?
DaneA
- DaneADec 28, 2016NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
