spforrest
Dec 01, 2017Aspirant
Firmware updates srx5308
I was seeing if there would be further firmware updates for srx5308. My understanding of the alert is there won’t. That 4/17 was the last. With the various network attacks going around, is it safe to ...
- Dec 04, 2017
You're welcome. :)
If ever you do not have further inquiries and since your concern has been addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
spforrest
Dec 03, 2017Aspirant
Thanks for your response. I figured not but wanted to check. I was considering upgrading to the utm150 but with the firmware updates being over will hold off. I will keep an eye out for new Netgear business devices. Thanks
DaneA
Dec 04, 2017NETGEAR Employee Retired
You're welcome. :)
Cheers,
DaneA
