SymmetryITAllan
Jun 01, 2017Follower
FR114P compatability with NBN FTTN
Is the FR114P compatible with the National Broadband Network Fibre To The Node technology. Is it just a matter of setting the router to cable rather than DSL to make it work.
Thanks
- DaneANETGEAR Employee Retired
Hi SymmetryITAllan,
Welcome to the community! :)
The FR114P is an old VPN Firewall model and its already EOL (End of Life). About FTTN, I believe that VDSL or VDSL2 technology is used to connect you to the Internet from the fiber connection. As per the data sheet of the FR114P here, it is not mentioned that it is compatible with VDSL or VDSL2.
I recommend that you use the compatible NETGEAR modem router for NBN FTTN connection. Kindly access and read the article below:
What is an NBN network and is my NETGEAR DSL modem router compatible?
DaneA
NETGEAR Community Team- DaneANETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
