Captain_Star's avatar
Captain_Star
FVS114 Router Login Took Too Long to Respond
When I attempt to login to the FVS114, I get the error message "www.routerlogin.com took too long to respond".
I have removed/re-inserted power and tried to login (nothing), did a hard factory reset and tried to login (nothing), cleared Win Edge browser cache (nothing), switched Edge to IE mode (nothing).
I have used a different ethernet cable for FVS114 to computer & gateway (nothing).
Am I to the point of accepting this device is pooched and I have to move on?
Any advice is appreciated.
Thanks, Kym.
    • op3c's avatar
      op3c
      NETGEAR Expert
      FVS114 TLS/SSL is too old and would be rejected by Chrome and Edge. If you have old Windows 7 PC, it may be able to access FVS114 GUI, Firefox used to be more lenient to outdated SSL/TLS versions, not sure if it still allows ancient deprecated TLS version.
      Your best bet is to find equally ancient laptop to access it. Or try http (not https) to see if GUI supports http.
  • schumaku's avatar
    schumaku
    Instead of depending on router login.com, give the effective LAN IPv4 address a try.
ProSupport for Business
