NGnimb22
Jun 29, 2022Tutor
FVS318 now obsolete: replacement?
Our trusty FVS318 is now the bottleneck in our new high speed fiber setup. I noticed in another discussion here that you recommend the BR500 as a replacement. But the BR500 doesn't have the eight por...
- Jun 30, 2022
Welcome to the community! 🙂
Be informed that both BR500 and BR200 are already EoL (End-of-Life). Currently, there is no 8-LAN port VPN Firewall available to offer.
You may want to check the SXR30 Orbi Pro WiFi 6 Mini AX1800 Router. Kindly check the specification on its data sheet here.
DaneANETGEAR Community Team
DaneA
Jun 30, 2022NETGEAR Employee Retired
DaneA
NGnimb22
Jun 30, 2022Tutor
Hmm. It seems that there are a lot of different ways to go at this little upgrade issue.
The modem our fiber service installed is the Arris NVG448B. If I go into the interface for this modem, it shows that there is a firewall enabled - with the usual (but a bit limited) controls such as:
Level
Packet Filtering
Port Forwarding
Port Triggering
Static NAT
DMZ
UPnP
Access Control
DoS
Blocking
ALG Passthrough
In addition, I run NOD32 software on all of our workstations. SO, I guess the question is, do I need to spend $$ on a new network firewall device, or can I really just upgrade to a couple of unmanaged Gigabit switches and run them into the existing modem? None of the workstations are on Wifi, only a few portable devices. My inclination is to get a pair of ProSafe GS108's, hook up all of our machines to them, and run the switch outputs to the modem. For a small network with basically one or two users, is this enough firewall protection? I am a web developer by trade, but have been dealing with computer hardware for many years.
TIA!
