ChrisColby
May 30, 2018Aspirant
FVS318G bricked. Help!
I have a FVS318G that served me well years ago, but moved and didn't need it until yesterday. It powered up just fine, and so I downloaded the latest firmware for it. When I tried to apply it, I got an "Invalid firmware" message. Some of the management pages worked, but many would give an <0 message on screen when I tried to go to them. Now, I can't even ping it. Any ideas how to fix? I was at 3.0.8 firmware (pulling from my memory... I can't manage it now). I've tried resetting to factory defaults, but it just ignores me (and I know I'm pressing the reset button as I can feel it click). Thanks.
- DaneANETGEAR Employee Retired
Hi ChrisColby,
Welcome to the community! :)
Kindly try the steps below:
1. Disconnect the FVS318G from your existing network and make sure its turned on. Get a straightened paper clip.
2. Insert the paper clip to the factory defaults hole then press and hold the factory reset button inside it for 30 seconds.
3. After 30 seconds, turn off the FVS318G while you still continue to press and hold the factory reset button. Wait for 5 seconds.
4. After 5 seconds, turn on the FVS318G while you still continue to press and hold the factory reset button. Wait for another 5 seconds.
5. After 5 seconds, release the paper clip from the factory reset button. Wait for the FVS318G to boot up properly and check if you are able to login to its web-GUI.
What is the behavior of the power LED, test LED and other LED lights of the FVS318G?
DaneANETEGAR Community Team
- ChrisColbyAspirant
Does this advice ever work? In researching my problem, I've seen this suggested numerous times (and I tried it), but have never seen it work. It didn't fix my switch.
When my switch powers up with nothing attached, first the power light comes on, and then an instant later the green light of all the ports come on for a half second or so, and then they all go out and just the power light remains lit. Shouldn't the 'Test' light come on for a few seconds? When I connect my laptop to it, the llink light for the port comes on and the amber 100mb light comes on as is appropriate. I try to ping the switch (192.168.1.1), and both the port's lights slowly flash, but the switch does not reply. All I did to break this was to try to load the latest firmware onto the switch. Just my laptop was connected to it, and it still bricked. Very disappointing, that, especially when I had done the same procedure a few times previously without incident. The switch is connected to a high quality surge protector, so I don't believe bad power fried it. Just the Netgear provided firmware did.
I"ve tried the TFTP procedures found elsewhere, but it can't find the switch (as evidenced by the switch not responding to my ping attempts). Any other ideas?
Thanks.
Chris
The FVS318G is not a switch, it is a VPN firewall router. Since the power reset procedure did not work and based from your observation of the LED lights, I conclude the FVS318G is faulty and it needs a replacement. I suggest you to open a chat or online support ticket with NETGEAR Support here at anytime. Kindly state the status of the FVS318G and the troubleshooting steps done. You will need to submit a .doc or .pdf copy of the Proof of Purchase of the FVS318G for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneANETGEAR Community Team
