OldPCGuy
Feb 07, 2016Aspirant
FVS318G v2 Basic Setup Question
My ISP upgraded/switched me from a cable modem to a Gateway. Now I can't use the FVS318 WAN port and FW, I have to use a LAN port essentially turning the firewall into an expensive switch. + I ma...
- Feb 16, 2016
Well I've decided to send the FVS318G back and use the Gateway firewall.
The gatway is supplied by the ISP so if and when I forgo the retal fee and buy my own gateway/modem I may be right back here where I started.
Till then...
Thx!
DaneA
Feb 08, 2016NETGEAR Employee Retired
Hi OldPCGuy,
Welcome to the community! :)
Kindly check this article and this might help you to verify if the gateway is properly set to bridge mode.
DaneA
NETGEAR Community Team
OldPCGuy
Feb 09, 2016Aspirant
The Gateway is in bridge mode; network is up; I have access to the internet; but....
I can't access the FVS318 GUI/Web page 192.168.1.1. I also can't acces the Gateway GUI/Web page 10.0.0.1. When I make a couple attempts I loose the internet connection as if somthing times out and drops the connection entirely.
And the only way I can get the gateway and FVS318 to talk is to turn on the FVS first and let is assign IP's to all the network devices then turn on the Gateway; wait 15-20 minutes then the internet connection is back.
Frustrating; this FW should be plug and play as a simple router.
- OldPCGuyFeb 09, 2016AspirantOK I stand corrected. GUI/web pages are now accessible for both the Gateway, and FVS318 FW. I'm not used to modems and routers taking so long to do their thing. :(
- DaneAFeb 10, 2016NETGEAR Employee Retired
Hi OldPCGuy,
I am glad that you are now able to access the web-GUI of both of your gateway and the FVS318Gv2. :) Hope that the internet connection is working fine.
DaneA
NETGEAR Community Team- OldPCGuyFeb 14, 2016AspirantDown again. :( :( ... two wasted weekends on this thing! I disconnected he FVS318 to re-route some Ethernet cables and it would not come back up no matter what re-start order I tried. The best I could do is ping netgear.com from the GUI. No internet, no gateway GUI. Why won't the FVS318Gv2 connect to the Technicolor TC8717C in bridge mode? I have a GS108Ev3 (8 port switch) and it works with the gateway in non-bridge mode.
