OldPCGuy
Feb 07, 2016Aspirant
FVS318G v2 Basic Setup Question
My ISP upgraded/switched me from a cable modem to a Gateway. Now I can't use the FVS318 WAN port and FW, I have to use a LAN port essentially turning the firewall into an expensive switch. + I ma...
- Feb 16, 2016
Well I've decided to send the FVS318G back and use the Gateway firewall.
The gatway is supplied by the ISP so if and when I forgo the retal fee and buy my own gateway/modem I may be right back here where I started.
Till then...
Thx!
OldPCGuy
Feb 15, 2016Aspirant
Dane,
Unfortunately no it still would not connect. I entered the;
IPv4 Address;
IPv4 Subnet Mask;
IPv4 Default Gateway;
IPv4 DNS Servers, (primary) & (secondary)
... matching what the computer was reporting connected directly to the gateway in bridge mode. II did not enter any IPv6 settings. Connecting the computer directly to the gateway in bridge mode or connecting through the GS108E in any mode and I'm up and online in 2-5 minutes reliably. With the FVS318 its as if by luck I got it to work the couple times I did.
DaneA
Feb 16, 2016NETGEAR Employee Retired
Hi OldPCGuy,
Since you have no problems with your previous cable modem and the FVS318Gv2, what I am thinking is its possible that it could be a compatibility issue between the Technicolor TC8717C and the FVS318Gv2. With regard to this, I encourage you to open an online case with NETGEAR Support for further assistance.
DaneA
NETGEAR Community Team
- OldPCGuyFeb 16, 2016Aspirant
Till then...
Thx!
