OldPCGuy
Feb 07, 2016Aspirant
FVS318G v2 Basic Setup Question
My ISP upgraded/switched me from a cable modem to a Gateway. Now I can't use the FVS318 WAN port and FW, I have to use a LAN port essentially turning the firewall into an expensive switch. + I ma...
- Feb 16, 2016
Well I've decided to send the FVS318G back and use the Gateway firewall.
The gatway is supplied by the ISP so if and when I forgo the retal fee and buy my own gateway/modem I may be right back here where I started.
Till then...
Thx!
DaneA
Feb 16, 2016NETGEAR Employee Retired
Hi OldPCGuy,
Since you have no problems with your previous cable modem and the FVS318Gv2, what I am thinking is its possible that it could be a compatibility issue between the Technicolor TC8717C and the FVS318Gv2. With regard to this, I encourage you to open an online case with NETGEAR Support for further assistance.
DaneA
NETGEAR Community Team
OldPCGuy
Feb 16, 2016Aspirant
Till then...
Thx!
