nousndthem
Aug 04, 2015Aspirant
FVS318Gv2: ping pcname results in ping pcname.netgear.com... need to remove suffix - case # 25539883
I just relpaced a broken FVS318G with a new FVS318Gv2 and have a configuration problem that I can't find a fix for.
I vaguely remember getting rid of this in the old FVS318G so that I could ...
DaneA
Aug 04, 2015NETGEAR Employee Retired
Hi nousndthem,
I just want to share this forum link below I found online and this might help you:
http://superuser.com/questions/97103/how-to-remove-local-dns-suffix-on-windows-7
Hope it helps. Welcome to the community :smileyhappy:
DaneA
Netgear Community Team
- nousndthemAug 04, 2015Aspirant
Thanks DaneA but it's not a Windows issue it's a new netgear product configuration issue.
The documentation isn't great.
A phone support call solved it. The solution is removing "netgear.com"
Network Configuration > Lan Setup > Edit VLAN Profile > Delete "netgear.com"Now ping pcname results in ping pcname with no suffix and a reply from the ping machine and my remote desktop connections are now working.
- DaneAAug 04, 2015NETGEAR Employee Retired
Hi nousndthem,
Thank you for your response and posting the solution.
I am glad that you have contacted Netgear Support and the problem is now resolved. :smileyhappy:
Cheers,
DaneA
