yk
Oct 21, 2016Aspirant
FVS318Gv2 Poor WAN to LAN throughput
Hi, Broadband upgraded to 200 Mbps last week. My firewall has the latest firmware. Connected through PPPOE. When PC is connected directly to modem (provided by ISP), speedtest indicates up/dow...
- Oct 21, 2016I asked this same quest some time ago, it doesn't supoport fastpath routing over PPPoE connections and is apparently a hardware limitation so you won't get much more than that, ever.
johnakajohn
Oct 21, 2016Tutor
- train_wreckOct 23, 2016Luminary
Wow, yet another limitation that isn't mentioned in the documentation.
I'm really glad I didn't deploy these at our company.....
- ykOct 23, 2016Aspirant
Thank you train_wreck, that's helpful.
- johnakajohnOct 24, 2016TutorI'd be happy for someone from support to contradict that however it was the end result of my support ticket on the subject and also held up by the results of my own tests using a linux box as a PPPoE server to eliminate any other factors. Those are some nasty typos in my initial response but I'm leaving them there.
Thank you Johnakajohn, that's helpful.
