Oceantech
Nov 09, 2016Follower
FVS318Gv2 won't respond to pings to WAN port
I installed an FVS318Gv2 about a year ago to provide a firewall between public and private networks in an industrial plant. Recently, my client asked me to change the WAN side IP address, which I've ...
Dan_Z
Nov 09, 2016NETGEAR Expert
Hi Oceantech,
Welcome to the community!
Please check the firewall rules,make sure there is no firewall rules to block ping.
In general,if want to ping FVS318Gv2 wan port,only to enable "Respond to ping on internet ports" on "Security->Firewall->Attack check" page.
Thanks.
phxdonald
Dec 02, 2016Aspirant
Any other replies to this, as Oceantech said he had already checked the "Respond to Ping on Internet Ports"? I am having this same issue, and am also unable to remote manage. I did just update the Firmware to 4.3.4-2 and ran a constant ping during the update and reboot process. During the reboot it did respond for about 5 requests but then went back to timing out.
- DaneADec 04, 2016NETGEAR Employee Retired
Hi phxdonald,
Welcome to the community! :)
Kindly answer the questions below:
a. Was it working before?
b. How is everything connected? It would be best if you post a diagram (.img or .png file) of your detailed network setup.
c. Is the WAN IP address registered on the FVS318Gv2 a Public IP Address?
DaneA
NETGEAR Community Team
- DaneADec 07, 2016NETGEAR Employee Retired
- phxdonaldDec 07, 2016Aspirant
I was able to figure this out. I had a LAN Rule for RDP setup, but I had failed to add the proper service/port, so all traffic was going trying to go to the IP in the LAN Rule. Once I straightened that out, everything else fell into place.
- DaneADec 08, 2016NETGEAR Employee Retired
Nice to know that you have figured it out. :) I'm glad it works now.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
