morris_aiu
Mar 28, 2016Aspirant
FVS318N - Clock skew detected
Model: FVS318N Firmware: 4.3.3-6 Problem: IPSec tunnel to PFSense router constantly fails and drops internet. Requires hard-reboot for it to come back up. This is a 4+ times a day thing. This ...
just_luc
May 16, 2016Tutor
Was a solution found to this? I am now having the same issue.
- DaneAMay 17, 2016NETGEAR Employee Retired
Hi just_luc,
Welcome to the community! :)
So far, there is no issues log about clock skew in the FVS318N. Kindly answer the questions below:
a. Do you have an IPSec VPN tunnel establish between two FVS318N?
b. Were you able to try the troubleshooting steps suggested on this forum thread?
c. What is the current firmware version of your FVS318N?
DaneA
NETGEAR Community Team
- morris_aiuMay 17, 2016Aspirant
Hello just_luc,
regretfully, no solution has been found.
Were you able to open an online case with NETGEAR Support? If yes, kindly share what happened.
DaneA
- JohnRoMay 20, 2016NETGEAR Employee Retired
Hello morris_aiu,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
