bu842
Mar 07, 2017Aspirant
FVS318N - switch doesn´t print on brother HL3040CN
Hello Community, my new switch doesn´t let the print jobs to my brother HL3040CN. I exchanged an old switch without any safety features with a FVS318N. The printer is connected via patch cable....
- Mar 08, 2017
DaneA wrote:
Have you checked the IP address of your brother HL3040CN printer? If not yet, kindly check if its getting a valid IP address from the FVS318N. Also, you may try to set a static IP address to the printer that is within the IP range of your existing network.
You might also try reinstalling the printer drivers on one of the PCs and see if that helps.
bu842
No, the printer is connected with a LAN cable to the FVS318.
DaneA
Mar 08, 2017NETGEAR Employee Retired
DaneA
NETGEAR Community Team
- StephenBMar 08, 2017Guru - Experienced User
- bu842Mar 08, 2017Aspirant
I did follow your suggest to install the printer driver new. That was the solution.
Thank´s for your help !!
