DonD's avatar
DonD
Guide
Mar 18, 2016
FVS318N discrepancy in LAN Groups database listing
Looking at the LAN Groups database listing screenshot below you will notice  "SancSW" is listed for IP 192.168.0.226, MAC dc:ef:09:d8:08:87; and also listed as "unknown" for the same IP but for MAC d...
  • DonD's avatar
    DonD
    Mar 21, 2016
    JohnRo,
    Regarding the two 192.168.0.226 entries, using the GS108E management utility, I checked the MAC of the SancSW and it is dc:ef:09:ce:19:98 and not dc:ef:09:d8:08:87.  So, I deleted the old SancSW entry in the database and then established a name SancSW on the correct database entry.  The table looks good now, however I do not trust the FVS318N "LAN Groups" database listing.  Besides the problem I just fixed, I noticed there are times when the router's wireless connections don't show up in the database, and times when they do.  Another,anomoly, When I create a specific name for an entry and get a new listing the table doesn't show the "*" for that entry when it is allocated an IP via the router's DHCP server.  I have to manually add the asterick to the name of that device.
    At least it no longer shows a duplicate entry for the same IP address.  I was concerned with that problem.
    Here is the new database listing:
    Thanks for you help JohnRo!
    DonD
ProSupport for Business
