blackbox
Jul 10, 2017Aspirant
FVS318N firmware 4.3.3-6 not allowing more than 8 wireless connections
Back in 2015 users reported that no more than 8 devices could connect on FVS318N. You can find the old discussion here https://community.netgear.com/t5/Business-Wireless/FVS318N-firmware-4-3-3-5-not-...
- Aug 03, 2017
At the end pressing the reset button for so much time factory reset everything and even the firmware upgarde worked after that.
Instead of doing all the configurations all again I gave it a go and restore my configurations and I now have 11 devices connected which seems the problem is now resolved.
blackbox
Jul 13, 2017Aspirant
The problem is not updating the firmware but the scratch part. We are a company and we have our port forwards Mac addresses static ips. This will cause a lot of time until we set everything back...
- JohnC_VJul 13, 2017NETGEAR Employee Retired
It seems that you were having a problem on upgrading the firmware of your FVS318N. Please do try upgrading the firmware through tftp. Please refer to this post on how to upgrade thru telnet.
- blackboxJul 13, 2017Aspirant
No, like I said the problem is because you are asking us to factory reset the router and set it again from scratch. Doing that it means we wont have internet for hours which is a big problem for us. If I could fix the problem with just the firmware upgrade then we could spare a few mins of downtime...
