deadbeef's avatar
Sep 05, 2016
FVS318G v2 - Fails to upgrade firmware
Trying to upgrade to latest firmware FVS318Gv2_V4.3.4-1
1) Reboot FVS318G v2
2) Navigate to Administration > Settings Backup & Upgrade
3) Browse to unzipped image FVS318Gv2_v4.3.4-1.img
4) Click Upgrade button
5) Within 2-3 seconds page reloads with connection reset
I tried using Internet Explorer, Firefox and Chrome all browsers produce same results. Any ideas how to upgrade firmware?
  • Upgrading via TFTP client did not work. TFTP could not establish connection.
    Solution was to upgrade firmware via Telnet client.
    Please note, this method requires TFTP server (not client) to be running on a PC. Once this is set up, telnet into router and upgrade via "util firmware_upgrade image_name.img TFTP_Server_IP" command.
    • deadbeef's avatar
      deadbeef
      Tutor
      • DaneA's avatar
        DaneA
        NETGEAR Employee Retired
        Hi deadbeef,
        I am glad to know that you were able to upgrade the firmware via Telnet client. :)   I appreciate that you have shared the solution you did here in the community.
        Feel free to post your future concerns here in the community.
        Regards.
        DaneA
        NETGEAR Community Team
  • JohnRo's avatar
    JohnRo
    Hi deadbeef,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks
ProSupport for Business
