deadbeef
Sep 05, 2016Tutor
FVS318G v2 - Fails to upgrade firmware
Trying to upgrade to latest firmware FVS318Gv2_V4.3.4-1 1) Reboot FVS318G v2 2) Navigate to Administration > Settings Backup & Upgrade 3) Browse to unzipped image FVS318Gv2_v4.3.4-1.img 4) Cli...
- Sep 09, 2016
Upgrading via TFTP client did not work. TFTP could not establish connection.
Solution was to upgrade firmware via Telnet client.
Please note, this method requires TFTP server (not client) to be running on a PC. Once this is set up, telnet into router and upgrade via "util firmware_upgrade image_name.img TFTP_Server_IP" command.
JohnRo
Sep 09, 2016NETGEAR Employee Retired
Hi deadbeef,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks
