blackbox's avatar
blackbox
FVS318N firmware 4.3.3-6 not allowing more than 8 wireless connections
Back in 2015 users reported that no more than 8 devices could connect on FVS318N. You can find the old discussion here https://community.netgear.com/t5/Business-Wireless/FVS318N-firmware-4-3-3-5-not-...
  • blackbox's avatar
    blackbox
    Aug 03, 2017
    At the end pressing the reset button for so much time factory reset everything and even the firmware upgarde worked after that.
    Instead of doing all the configurations all again I gave it a go and restore my configurations and I now have 11 devices connected which seems the problem is now resolved.
ProSupport for Business
