R1Limited
Dec 03, 2014Aspirant
FVS318n, IP range to allow ICMP Wan Ping incoming help
I have a need to setup a range of external IPs to be able to ping my router. Off course the settings in security > firewall > attack checks allow for a single IP to ping or all under espond to Pin...
Nhellie
Dec 04, 2014Virtuoso
ah.. bummer :eek:
So it does not respond on the specified range? or any random IP?
Do you want the LAN to respond to the request? if yes.
make sure "Disable Ping reply on LAN ports" is unchecked.
