ridgedale
May 25, 2016Aspirant
FVS318N Login Issue
I wonder if anyone elee has encountered the situation where an FVS318N is rejecting all login attempts despite the usernames and passwords entered being correct. Each time I attempt to login I get t...
- Jun 02, 2016
Hi John,
Apologies for the belated response.
In the end I managed to login to the router and reboot it using telnet, which seems to have resolved the issue. There was nothing wrong with the login credentials being used. Very bizarre.
Kind Regards
Dene
JohnRo
May 27, 2016NETGEAR Employee Retired
Hello ridgedale,
Does this happen on the SSL-VPN portal only or it is also the same when you are accessing the management interface?
Looking forward to your response.
Thanks,
