ridgedale
May 25, 2016Aspirant
FVS318N Login Issue
I wonder if anyone elee has encountered the situation where an FVS318N is rejecting all login attempts despite the usernames and passwords entered being correct. Each time I attempt to login I get t...
- Jun 02, 2016
Hi John,
Apologies for the belated response.
In the end I managed to login to the router and reboot it using telnet, which seems to have resolved the issue. There was nothing wrong with the login credentials being used. Very bizarre.
Kind Regards
Dene
JohnRo
May 30, 2016NETGEAR Employee Retired
Hi ridgedale,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- ridgedaleJun 02, 2016Aspirant
Hi John,
Kind Regards
Dene- JohnRoJun 02, 2016NETGEAR Employee Retired
Hello Dene,
It's great to know you have it working again! That was weird considering nothing was changed. Please mark your last response as "Accept as Solution" so that it will help other members when they encounter the same issue.
Thanks,
