ridgedale
May 25, 2016Aspirant
FVS318N Login Issue
I wonder if anyone elee has encountered the situation where an FVS318N is rejecting all login attempts despite the usernames and passwords entered being correct. Each time I attempt to login I get t...
- Jun 02, 2016
Hi John,
Apologies for the belated response.
In the end I managed to login to the router and reboot it using telnet, which seems to have resolved the issue. There was nothing wrong with the login credentials being used. Very bizarre.
Kind Regards
Dene
ridgedale
Jun 02, 2016Aspirant
Hi John,
Kind Regards
Dene
JohnRo
Jun 02, 2016NETGEAR Employee Retired
Hello Dene,
It's great to know you have it working again! That was weird considering nothing was changed. Please mark your last response as "Accept as Solution" so that it will help other members when they encounter the same issue.
Thanks,
