PETROV
Dec 19, 2016Tutor
FVS318N Login Issue
I have bricked my firwall after a factory reset, After a reboot it seems to boot normaly but nothing works (only as a hup) Now i can nolonger access the device, I am not able to telnet or web acce...
DaneA
Dec 19, 2016NETGEAR Employee Retired
Hi PETROV,
Welcome to the community! :)
Let us try to power reset the FVS318N. Kindly do the steps below:
1. Disconnect the FVS318N from your existing network and make sure its turned on. Get a straightened paper clip.
2. Insert the paper clip to the factory defaults hole then press and hold the factory reset button inside it for 30 seconds.
3. After 30 seconds, turn OFF the FVS318N while you still continue to press and hold the factory reset button. Wait for 5 seconds.
4. After 5 seconds, turn ON the FVS318N while you still continue to press and hold the factory reset button. Wait for another 5 seconds.
5. After 5 seconds, release the paper clip from the factory reset button. Wait for the FVS318N to boot up properly. Observe the LED lights as well.
6. After it boots up, connect a PC/laptop to any LAN port of the FVS318N then try to login to its web-GUI.
Kindly answer the questions below:
a. What is the behavior of the LED lights after doing the power reset?
b. Are you able to get a valid IP address when you connect a PC/laptop to any port of the FVS318N?
c. Are you able to access and login to the web-GUI of the FSV318N/
DaneA
NETGEAR Community Team
PETROV
Dec 20, 2016Tutor
After i have done al the above
the device boots, green LED is on
Alle the lan leds light en go off again
the orange (test) LED goes on for some time
Orange turns off and the second green LED goes on Wireless
After this i can connect a lan cable the indicators shows green and orange,
I do not get a valid ip address on my PC.
I can not access the web-GUI, i can not ping any IP addres 192.168.1.1 or 192.168.0.1
When connecting to the console i get a lot of errors see message below
what can I do to solve this
Thank you for looking in to this
U-Boot 2008.10-mpcore-svn70 (Dec 16 2013 - 13:31:40)
Cavium Networks CNS3XXX SDK v0.7-1202
CPU: Cavium Networks CNS3000
ID Code: 410fb024 (Part number: 0xB02, Revision number: 4)
CPU ID: 900
Chip Version: c
DRAM: 128 MB
Flash: 32 MB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
CPU works at 300 MHz (600/1/2)
DDR2 Speed is 266 MHz
switch/phy reset
## Starting application at 0x03000000 ...
Hello ,This is SC world!
BootVersion SC V105,Build Time:Dec 16 2013 - 13:31:26
## Application terminated, rc = 0x0
checking the integrality of linux ... ...
flen is :1a84f00
fcrc is :2632bc82
vmoffset is :100
vmsize is :818ffe
vmcrc is :5b0b7266
crc caled is :5b0b7266
kernel length is :8491006(0x818ffe)
fw version is :4.3.3-5
checking pass..
Hit any key to stop autoboot: 0
enter do_eth_down!!!
## Starting application at 0x02000000 ...
Uncompressing Li.................................................................................................................... done, booting
Linux version 2.6.31.1-cavm1 (root@localhost.localdomain) (gcc version 4.3.3 (Buildroot 2010.05) ) #1 Wed Jun 3 13:06:54 IST 2015
Cavium Networks CNS3XXX SDK v1.1-1952
CPU: ARMv6-compatible processor [410fb024] revision 4 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: Cavium Networks ARM11 MPCore
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: root=/dev/ram0 rw init=/linuxrc mem=128M console=ttyS0,9600
PID hash table entries: 512 (order: 9, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 119508KB available (3324K code, 252K data, 116K init, 0K highmem)
NR_IRQS:96
console [ttyS0] enabled
Calibrating delay loop... 119.60 BogoMIPS (lpj=598016)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Initializing CNS3XXX L2 cache controller... done.
Initializing CNS3XXX DMA controller
First time microcode alloc for channel 0 done @phy:26057000
First time microcode alloc for channel 1 done @phy:26058000
First time microcode alloc for channel 2 done @phy:26059000
First time microcode alloc for channel 3 done @phy:2605a000
First time microcode alloc for channel 4 done @phy:2605b000
First time microcode alloc for channel 5 done @phy:26030000
First time microcode alloc for channel 6 done @phy:26031000
First time microcode alloc for channel 7 done @phy:2602e000
First time microcode alloc for channel 8 done @phy:2602f000
Cavium EVB Board version 1.x
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Slow work thread pool: Starting up
Slow work thread pool: Ready
FS-Cache: Loaded
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 6448K
CNS3XXX PCIe Host Control Driver
pci_common_init(&cns3xxx_pcie0); is marked off to disable pci-e0
PCI-E1 uses internal clock source.
Enable PCIe PMU CLK
patch to disable pcie0
Enable PCIe1 Internal CLK
PCIE-1 equalizer setting, val:0xe2c
Active PCIe1 Clock, PHY and reset PCIe
PCIe: Port[1] Enable PCIe LTSSM
PCIe: Port[1] Check data link layer...Link up.
PCIe: Set Device Max_Read_Request_Size to 128 byte
pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0001:00:00.0: PME# disabled
pci 0001:00:01.0: PME# supported from D0 D1 D3hot
pci 0001:00:01.0: PME# disabled
PCI: bus0: Fast back to back transfers disabled
PCI: bus1: Fast back to back transfers enabled
PCIe1: Bridge found.
PCI: enabling device 0001:00:00.0 (0140 -> 0143)
PCIe1 map irq: 0001:00:00.00 slot 0, pin 1, irq: 88
PCIe1 map irq: 0001:00:01.00 slot 1, pin 1, irq: 62
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 246
alg: No test for cipher_null (cipher_null-generic)
alg: No test for ecb(cipher_null) (ecb-cipher_null)
alg: No test for digest_null (digest_null-generic)
alg: No test for compress_null (compress_null-generic)
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler cfq registered (default)
cns3xxx_spi_probe: setup CNS3XXX SPI Controller in polling mode, w/o DMA
Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x78000000 (irq = 45) is a 16550A
brd: module loaded
loop: module loaded
cns3xxxflash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
cns3xxxflash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
CNS3XXX NOR flash: Using static partition definition
Creating 8 MTD partitions on "cns3xxxflash":
0x000000000000-0x000000040000 : "UBoot"
0x000000040000-0x000000060000 : "Manuinfo "
0x000000060000-0x000000080000 : "Calibration "
0x000000080000-0x000000980000 : "Kernel"
0x000000980000-0x000001de0000 : "File System"
0x000001de0000-0x000001fe0000 : "Configure"
0x000001fe0000-0x000002000000 : "UBootEnv"
0x000000000000-0x000002000000 : "ALL"
Initialize PHY s/w auto-polling
CNS3XXX PSE: Initialize
MAC 0
Initialize BCM53115M
enable UNKNOW_TAP_TOCPU
bcm53115M device id:(0x53128)
MAC 1
Initialize brcm50612
MAC 2
jumbo_frame off
MAX_PACKET_LEN:1536
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
CNS3XXX Real Time Clock, (c) 2009 Cavium Networks
rtc irq:23
cns3xxx-rtc cns3xxx-rtc: rtc core: registered cns3xxx-rtc as rtc0
i2c /dev entries driver
i2c-gpio i2c-gpio.1: using pins 1 (SDA) and 0 (SCL)
cns3xxx_i2c_init:
cns3xxx_i2c_probe:
GACT probability NOT on
Mirror/redirect action on
u32 classifier
Performance counters on
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
ipt_account 0.1.7 : Piotr Gasid▒o <quaker@barbara.eu.org>, http://www.barbara.eu.org/~quaker/ipt_account/
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 4
cns3xxx-rtc cns3xxx-rtc: setting system clock to 1970-01-01 00:00:00 UTC (0)
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing init memory: 116K
/etc/init.d/rcS starting
Booting FVS318N User Space...
Mounting file systems
SQUASHFS error: zlib_inflate error, data probably corrupt
SQUASHFS error: squashfs_read_data failed to read block 0xf30447
SQUASHFS error: Unable to read fragment cache entry [f30447]
SQUASHFS error: Unable to read page, block f30447, size c279
insmod: read error from '/pfrm2.0/lib/modules/spp[kernel mode] CNS3XXX_ARL_TABLE_ADD
e.ko': Input/output error
insmod: can't insert '/pfrm2.0/lib/modules/sppe.ko': Input/output error
Enabling Quiet Boot...Done
Setting up loopback
net.ipv6.conf.eth1.accept_ra = 0
Setting Hostname... Done.
Sat Jan 1 00:00:00 UTC 2011
Jan 1 00:00:00 FVS318N syslog.info syslogd started: BusyBox v1.17.4
starting tr69 daemon configuration....done
umiInit failed
loggingInit failed
SQL error near line 3: no such table: sqliteLock
starting firewalld Daemon...Done
inserting default firewall rules
Restoring certficates from persistant storage...Done
Starting pnac daemon...Done
iwpriv wifi0 setCountryID 528Starting dot11 daemon...Done
Loading WpsPB Module..umiInit failed
rebootd : umi initialization failed
starting SNMP Daemon...Done
Starting the cron deamon...Done
starting ntpd Daemon...Done
Starting NIMF daemon... Done
Starting LINKDETECT daemon... Done
Creating /dev/pts/0 pseudo device for L2TP <-> PPP communication... Done
Starting IKE Daemon...
Failed to Open /dev/bcmDebug device
Done
Done
Starting VPN KEEP ALIVE Daemon...Done
Bandwidth Profile Initialization...Done
SSLVPN Intialization ....... Done
Webserver Starting....Done
Creating Dummy Config File
Restoring configuration from persistant storage...
SQL error near line 3: no such table: defaultMac
SQL error near line 4: no such table: defaultMac
SQL error near line 5: no such table: defaultMac
SQL error near line 6: no such table: unitInfo
SQL error near line 7: no such table: ipAddressTable
Making Brand.conf...
Loading Factory Defaults Modulescan't open device gpio-device
Inserting the bcm debug module...Done
Inserting the power saving module...Done
making database from system settings...
ifDevUpdtMac SQL error: no such table: ethernet
SQL error near line 4: no such table: ConfigPort
Copying necessary files for L2TP Server...
Done
Executing bcmRegConfig...
bcmRegConfig :Failed to Open /dev/bcmDebug device
Done
Dumping SYSTEM_MENU_INFO
hwver: 00:00:A0:03
reginfo: 0x0003
numofimages : 1
currimage: 1
mac address : 6CB0CE763DC8
wireless MAC[0] : 6cb0ce763dda
wireless MAC[1] : 6cb0ce763ddb
wireless MAC[2] : 6cb0ce763ddc
wireless MAC[3] : 6cb0ce763ddd
vlan[0] MAC : 6cb0ce763dcb
vlan[1] MAC : 6cb0ce763dcc
vlan[2] MAC : 6cb0ce763dcd
vlan[3] MAC : 6cb0ce763dce
vlan[4] MAC : 6cb0ce763dcf
vlan[5] MAC : 6cb0ce763dd0
vlan[6] MAC : 6cb0ce763dd1
vlan[7] MAC : 6cb0ce763dd2
vlan[8] MAC : 6cb0ce763dd3
vlan[9] MAC : 6cb0ce763dd4
vlan[10] MAC : 6cb0ce763dd5
vlan[11] MAC : 6cb0ce763dd6
vlan[12] MAC : 6cb0ce763dd7
vlan[13] MAC : 6cb0ce763dd8
vlan[14] MAC : 6cb0ce763dd9
WAN MAC : 6cb0ce763dc9
pcbasn number : R.YX249204D6
serial number : 3BT349BD00404
image 0 : 4.3.3-5
image 1 : 0
productId : FVS318N
maccnt0: 0x22
maccnt1: 0x0
maccnt2: 0x0
maccnt3: 0x0
Done
Wed Jun 3 10:13:30 UTC 2015
Secure Gateway Solution for FVS318N
FVS318N login:
- DaneADec 20, 2016NETGEAR Employee Retired
Hi PETROV,
Based on the results you have posted, it seems that the FVS318N got faulty. With regard to this, I suggest you to open an online case with NETGEAR Support at anytime. State what happened to your FVS318N and the troubleshooting steps we tried. Attach a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of your FVS318N for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
- PETROVDec 21, 2016Tutor
I am not able to open an online case or upload documents
I can call or open a chat
I do have the proof of purchase, but did not register the firewall as the equipment has been used on different places by different people
- DaneADec 26, 2016NETGEAR Employee Retired
Hi PETROV,
If ever you were able to open an online case with NETGEAR Support, kindly keep us posted about the progress of it.
DaneA
