joe_schmo
Aug 07, 2017Tutor
FVS318N Loses Connectivity
Problem: - It provides DHCP to all devices on my network. All devices lose internet connectivity, but keep local connectivity. - Cannot telnet or access the FVS318N I have to turn off the de...
DaneA
Aug 08, 2017NETGEAR Employee Retired
Hi joe_schmo,
Let us isolate the problem:
a. If you will disconnect the FVS318N from the modem then connect your PC or laptop directly to the modem, are you able to access the internet just fine?
b. Are there any changes within the settings of the FVS318N that might have triggered the problem?
c. Have you tried to factory reset the FSV318N then reconfigure it from scratch and check if same problem will occur?
DaneA
NETGEAR Community Team
joe_schmo
Aug 09, 2017Tutor
Yes, if I bypass the FVS318N, I can get to the internet.
I've factory reset and re-done all the config.
Two days ago aI turned off the UDP Flood Check and disabled DNS Proxy setting in the network settings.
That seems to be better.
But every day at 1AM, I lose the ability to ping the router, and any outside website. Strangely, skype stayed active for a while before I had to power off the router and power it back on.
It then loses connection sometime between 1AM and 6AM.
So something is up, and it's regularly occiring.
