Aneurysm
Nov 20, 2017Tutor
FVS318N not working with new modem-router
Hi, I'm trying to connect the ProSafe FVS318N to a new modem-router but it doesn't work, without the FVS318N internet connection works on every PC on the LAN. This is the story: in the past years I ...
Aneurysm
Nov 22, 2017Tutor
I'll try to change the Modem-router IP instead of the Prosafe one, thank you in advance
JohnC_V
Nov 22, 2017NETGEAR Employee Retired
Please let us know if everything works fine right after you change the IP of one the routers that you have so that we may know if that is the one causing the problem.
- AneurysmNov 28, 2017Tutor
Changed again the modem-router IP and not it's working, thank you.
