mulox
Jan 16, 2017Aspirant
FVS318N requires frequent reboot
I bought this firewall about 1 year ago and never upgraded the original firmware so it was very, very old, I think 4.0 or earlier, don't recall (now I am wishing I would have backed up the old firmwa...
ChenX
Jan 16, 2017NETGEAR Expert
Hi mulox
Welcome to the community!
If you upgrade to v 4.3.4-2 from very old firmware,I suggest you do a factory reset.
Or can you try to fix the ip address to see if it still has the issue?
Regards
SamirD
Feb 15, 2017Prodigy
Be sure to factory default the configuration and rebuild your configuration from scratch. The FVS (and other manufacturer's routers as well) do weird things when remnents of the old firmware configuration runs on the newer firmware.
