itdept_2
Jul 28, 2025Initiate
FVS318v3 slow speeds as Router fast as Hub what settings can I change (internally on netgear)
My FVS 318 v3 is only 7 & 8 Mbps as a Router but it speeds up to (94 & 67 Mbps when modem cable is moved from WAN to a LAN port. what inside the Netgear is slowing down speed. No Port Fwrd, no Rules,...
itdept_2
I'm also thinking that the Spec. showed 11 Mbps per port limitation.
