lochnagar
Mar 23, 2017Aspirant
FVS336G - no web access after firmware upgrade
Hello - I've just upgraded the firmware to the latest version on a FVS336G and I can no longer get into the web access. After the "upgrade" the web browser didn't go back the netgear firewall webpag...
- Mar 26, 2017
Kindly answer the questions below:
a. Have you tried to clear the cache on the browser then try to access the web-GUI of the FSV336Gv2?
b. What is the behavior of the LED lights of the FVS336Gv2?
c. Have you tried to using other PCs or laptops to access the web-GUI of the FSV336Gv2?
DaneA
NETGEAR Community Team
DaneA
Mar 29, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
lochnagar
Mar 29, 2017Aspirant
Hi DaneA,
Thanks for getting back, sorry for the delay in replying.
I tried a second computer and the GUI worked with that. The firmware did update did go through. I've subsequently tried on the orignal computer, and the GUI now works with that too.
So I'm left a bit confused as to why it didn't work originally, but happy that the unit isn't bricked. So thanks for your suggestion in trying another PC.
Chris
