hmg21215
Dec 08, 2011Aspirant
FVS336G and Bluecoat Filter/ IPSec
We have a FVS336Gv2 router. We are setting up the Threatpulse web filter form Bluetooth. It can work with an IPSec tunnel to their site which provides the filtering. Their tech support helped me se...
adit
Dec 12, 2011Mentor
The Remote IP cannot be set to ANY. You need to specify the correct subnet.
Otherwise all destination IP's other than yours will be directed across the tunnel, like the problem you have now.
