olig
Jul 27, 2016Aspirant
FVS336G limit SIP server for Voip
Dear Netgear Community We have a new VoIP solution installed together with an existing Netgear FVS336G V2. Is there a way to configure the FVS336G V2 to limit the SIP signals to only come from the ...
- Aug 07, 2016
Hi olig,
Since your VoIP provider has suggested it then it means that it might help for the VoIP solution to function well. Try to follow the suggestion then observe what happens. If ever it doesn't help then you may just delete the rules then inform your VoIP provider about it.
DaneA
NETGEAR Community Team
DaneA
Jul 27, 2016NETGEAR Employee Retired
Hi olig,
Welcome to the community! :)
Kindly answer my questions below:
a. How is everything connected? Kindly post a screenshot or image of your detailed network setup.
b. What is the current firmware of the FVS336Gv2?
c. Does your VoIP provider mentioned that you need to open ports for the new VoIP solution? If yes, what are the port numbers needed to be opened and to what IP addresses should it be opened?
I look forward to your response.
DaneA
- oligJul 28, 2016Aspirant
Hi DaneA
Thanks for the prompt reply.
- The setup is very simple and straightforward: Internet signal coming through a modem/router to WAN1 of the Netgear FVS336G. From there LAN1 goes to a Smart Switch which leads to the different workstations and IP phones. IP address to the outside world is fix.
- I’m afraid there hasn’t been an update for quite a while. Firmware – Version: 3.0.6-28
- The VoIP provider initially gave me the following information:
IP range for communication WAN/LAN and LAN/WAN
Where do I configure this?
UDP Ports
Done
IP range for configuration LAN/WAN for http:// and http://
TCP ports WAN to LAN and LAN to WAN
Forgive my ignorance, but would these parameters set correctly already limit the SIP signals to only come from the provider, or do we need additional settings?
Thanks and regards
Oliver
- DaneAJul 28, 2016NETGEAR Employee Retired
Hi olig,
I think you could configure the IP range on the Firewall LAN WAN rules. Kindly refer to the figure on page 230 of the FVS336Gv2 reference manual here. As you can observe, you can select IP Range on "Send to LAN Server."
DaneA
- DaneAJul 31, 2016NETGEAR Employee Retired
Hi olig,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- oligAug 02, 2016Aspirant
Hi DaneA
Sorry for not replying earlier, we had a long weekend due to a local holiday.
I think I'm getting closer now and I can see where to set the IP range:
However the provider is giving me 4 different IP ranges:
- 212.55.abc.def- 212.55.uvw.xyz
- 77.59.aaa.aaa-77.59.zzz.zzz
- 62.2.bbb.bbb - 62.2.yyy.yyy
- 62.12.ccc.ccc– 62.12.xxx.xxx
How can I tell which is the relevant one?
Or if all 4 are required, where do I set them?
Thanks and regards
olig
