aloha2000
Jul 11, 2016Aspirant
FVS336G site to site VPN need only ip phone traffic going through the tunnel
I am trying to connect 2 locations using 2 FVS336G routers. Location A is using an FVS336G to route VOIP traffic. Location B with be using one internet connection to route internet traffic and VOIP...
- Jul 19, 2016
DaneA, thank you for your response. I haven't try your suggestion because I ended up going a different direction and not connecting the 2 sites with VPN.
Thanks again for your help!!
DaneA
Jul 14, 2016NETGEAR Employee Retired
Hi aloha2000,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
aloha2000
Jul 19, 2016Aspirant
