thorsbro
May 21, 2010Aspirant
FVS336G stuck on yellow "Test"
Hi Netgear Forum, I have a FVS336G and I experience that some times the router stops functioning and when I look at the router the yellow "test" light is on. Sometimes it goes away after 5-10 mi...
jmizoguchi
May 21, 2010Virtuoso
if you power up the router , it can take few minutes detect and negotiate the connection on WAN. Time takes to fully boot up is usually WAN related.
what is broadband type. symptom do seen on cable services as IP may on WAN becomes private IP instead of public IP from the ISP. since you can not ping or login router interface I have to assume.
try upload latest firmware and
1 hard reset the router after flashing firmware
2. do NOT restore router config file . Manually configure
see how that goes
see how that goes
