thorsbro
May 21, 2010Aspirant
FVS336G stuck on yellow "Test"
Hi Netgear Forum, I have a FVS336G and I experience that some times the router stops functioning and when I look at the router the yellow "test" light is on. Sometimes it goes away after 5-10 mi...
thorsbro
Jun 03, 2010Aspirant
It seems to be WAN related.
The WAN1 'ACTIVE' LED is Amber color meaning that the WAN connection is down, and the router is trying to do a "fail over". I have set it to use one WAN port only, so shouldn't it just say that it has no internet connection instead of going into this "no response" mode?
I find it odd that I can not connect to the router while this is going on. The LAN ports are all green.
Oh and I forgot to mention that it is a FVS336v1, and I have the newest firmware update on it.
