thorsbro
May 21, 2010Aspirant
FVS336G stuck on yellow "Test"
Hi Netgear Forum, I have a FVS336G and I experience that some times the router stops functioning and when I look at the router the yellow "test" light is on. Sometimes it goes away after 5-10 mi...
jmizoguchi
Jun 03, 2010Virtuoso
thorsbro wrote: It seems to be WAN related.
The WAN1 'ACTIVE' LED is Amber color meaning that the WAN connection is down, and the router is trying to do a "fail over". I have set it to use one WAN port only, so shouldn't it just say that it has no internet connection instead of going into this "no response" mode?
I find it odd that I can not connect to the router while this is going on. The LAN ports are all green.
Oh and I forgot to mention that it is a FVS336v1, and I have the newest firmware update on it.
make sure when you flash newest firmware from older firmware, HARD RESET and manually configure first.
