thorsbro
May 21, 2010Aspirant
FVS336G stuck on yellow "Test"
Hi Netgear Forum, I have a FVS336G and I experience that some times the router stops functioning and when I look at the router the yellow "test" light is on. Sometimes it goes away after 5-10 mi...
thorsbro
Jun 03, 2010Aspirant
It so happens that my old firewall broke down, and I then sent it in to support and they sent me a new back. Nice support. :)
I started by updating the firmware, and then I manually reconfigured the firewall. But do you think I will benefit from doing a "factory reset" and redo the configuration?
Thank you for the fast replies.
